Regule moteur ,mais apparament quand la consigne ne peut etre gardé le systeme baissera le pas collectif pour reprendre des tours.
Cf le texte :
Not too much information, but Spartan is working on their newgovernor, incorporating a mixture control, and a collective managementfeatures all into one box. The collective management feature works asthe following, “The iGV will use the target rpm to manage the throttleas you would expect. Once the engine has reached it’s maximum outputand HS is still sagging, the system will then reduce collective tomaintain the targeted rpm setting. All indicators are that you arebetter off maintaining HS vs having a lot of pitch in the blades andlower HS.”
Looks interesting, and waiting for more information to become available.
Encore des essais et pas mal de tests....
a suivre
