Spektrum RC: AR7300BX Flybarless System Announced
The new AR7300BX Flybarless system announced by Spektrum RC . Now with an integrated power bus for HV setups. The AR7300BX gives you the security of a 7-channel, DSMX® receiver with the precision of a BeastX® flybarless system in a single unit. It’s simple to use too. No special programming interface is needed for setup […]
Source: Helidaily Voir l’article complet
post-12499-0-12817900-1405277942_thumb.p
The AR7300BX gives you the security of a 7-channel, DSMX® receiver with the precision of a BeastX® flybarless system in a single unit. It’s simple to use too. No special programming interface is needed for setup and adjustment. All you need is the DSM2® or DSMX transmitter it’s bound to.
Complementing this incredible technology is an integrated power bus that eliminates the need for BEC regulators. It can also handle the demanding current loads of high-voltage servos. It’s this robust power delivery system that makes the AR7300BX a great choice for big 550- to 800-size electric helis or .50- to .90-size gas/nitro machines.
Included with the system is a specially designed switch harness. Should the switch fail, it has been designed to fail in the ‘on’ position.
A USB programmer for making firmware updates is available separately.
For more details visit: http://spektrumrc.com/Products/Default.aspx?ProdId=SPMAR7300BX
