SK 720 ...
j'ai reçu ce petit email de skookum...
Yes, we're working on a 3-axis named the SK-720. It's still a few months from release. It's much more than just a 3-axis though, it also includes accelerometers, build in USB, a micro-SD card, gps port, spektrum receiver ports, etc. Of course, it will also cost more.
Ya pu ka attendre et voir
A+ et bons vols
  • 3 months later...
  • 5 months later...
Ca y est il est arrivé sur le marché et dispo en France ---->ici<---- :wink::wink:
FEATURES
* Easy set up for first-time users
* Flybarless stabilization with piro-compensation
* Built-in tail gyro, supporting most all tail servos by name in the setup software
* Supports use as a 9-channel receiver core when used with 2.4 GHz
satellite receivers (two dedicated Sat-RX ports)
* Works with Digital or Analog swash servos
* Suitable for 120, 135/140, and 90 degree eCCPM, as well as mCCPM swashplates
* Works with 2,3,4, or 5 blades, with phase trim adjustable to +-90°
* Swash Ring anti-binding algorithm
* Internal swash mixing, for accurate control
* Supports radios with either 1024 or 2048 servo steps, and 22ms or 11ms frame rates
* Can also be used with traditional R/C receivers
* Expansion port for future accessories such as GPS
* 38 x 30 x 14 mm, 17 grams
* 8.5 volt capable
* Optional 25 amp external power bus (included) for larger than 50-size and nitro helis (15 grams). Make brownouts a thing of the past!
* 3-axis accelerometer + 3 gyros, allowing self-leveling
* High-power 32 bit processor (for future upgradeability)
* Expansion port for GPS or a third sat-receiver
* Up to 10 servos (one tail servo, 4 digital swash servos, and 5 analog servos)
* Port for a remote indicator LED , which you can mount outside of the canopy
* Built in micro-SD card (2 GB flight-data logging)
* Built in USB mass storage device - Connect the unit to your computer without having to install drivers
* Flight data logs can be played back on your PC with analysis of tuning and heli health
* Compatible with the Skookum SK-LCD terminal
* Existing SK360 setup files can be easily up-converted for the new unit
Pour celles et ceux qui seraient intéressés par le SK720, vous pouvez utilisez le code remise sk7201day sur le site RC SUPERSALES , ça valide une remise de james bond 007 fois 11 usd par rapport au prix affiché ( soit R=18.33% env ), j'ai reçu cette newsletter hier.
Faites en bonne usage.
Disponibilité ici également: http://cgi.ebay.fr/ws/eBayISAPI.dll?ViewItem&item=290450461124&ssPageName=STRK:MEWAX:IT
A+FRED
