MiniCopter’s Diabolo 800+
Check out the new 3D creation from Minicopter.
The Diabolo has a belt drive tail rotor with automatic length adjustment that utilizes a spring loaded damper. This helps keep tension on the belt. The two stage helical gear setup keeps the noise low. The Diabolo will accept up to 830mm main blades and 140mm tail blades. This heli has a maximum head speed of 1750.
Features:
  • Up to 830mm blades
  • Automatic length adjustments by spring loaded damper for belt.
  • Smooth quiet belt drive transmission
  • High center of gravity battery placement
  • Unique German designTwo-stage, low noise helical spur gear
  • Multiple canopy color choices.
  • Low head speed flight
Learn more about this product here.
Source: RcHeliResource Voir l’article complet
