Sign in to follow this
djedje
Upgrade AVANT pour les Aurora
AVANT a établie une liste des pièces qui ont évolué dans le temps!
voici le détail:
The changes from 2010 to 2011 have been:
00) All kits and spares are now much lower priced.
01) AV900240 - All kits now come with the Smooth Spindle
02) AV000130 - All kits now come with Semi-rigid dampeners.
03) AV900239 - All kits now come with 4mm jesus pin hole in main shaft.
04) AV000801 - All kits now come with 4mm jesus pin.
05) AV900223 - All kits now come with 4mm pin hole main sleeve.
06) AV900211 - All kits now come with slightly enlarged constant drive gear for tighter mesh.
07) AV910300, 301 - Nitro kit frames have both back and top front gyro mount locations for gyros that now come with very short leads.
08) AV920350, 351 - All Electric frames have now longer slots for larger heavy batteries.
09) AV000108 - Electric frames have an extra 26mm spacer
10) AV000100 - Electric was released with square mainshaft bearing blocks instead of the ones used in the nitro for no need for block orientation.
11) AV920350, 351 - Electric frames now have ESC on the left side
12) AV000123, 124 - Metal balls fit without a need to resize or squeeze the ball links
13) AV900202 - Torque tube is stiffer and harder
14) AV900239 - Stronger solid mainshaft is now the default for all the kits.
15) AV000115 - Flybar carrier mounting sleeves allow for more thread inside the flybar carrier.
16) AV000801 - Tail pulley shaft pins are now easier to insert.
17) AV900256 - All kits both nitro and electric now come with painted canopies.
18) AV900244 - Avant Tail Rotor Assembly comes with socket head caps screws for the tail blade grips instead of round head ones.
19) AV900248 - Avant Tail Box Clamp material is now more rigid
20) AV910309 - Avant Cooling Fan is now made of a material that withstand more abuse.
April 2011:
New recently released with kits that are currently shipping:
21) AV900212 - More precise Main Gear. (Can be identified by an Avant Logo and the words 99T)
22) AV900211 - More precise Constant Drive Gear. (Can be identified by an Avant Logo and the words 97T)
23) AV920355 - e-Aurora Hi-Torque Frame Reinforcer Plate Kit for high power motors comes now default with new electric kits.
24) AV910312 - Avant Clutch new geometry minimizes metal fatigue
New optional parts
25) AV920356 - Avant e-Aurora Pinion 11 Tooth Assembly
26) AV920357 - Avant e-Aurora Pinion 12 Tooth Assembly
27) AV920355 - Avant e-Aurora Carbon Hi-Torque Frame Reinforcer Plate Kit for high power motors
28) AV000910 - Avant Bladeholder/caddy
29) AV910322 - Avant Large FBL Unit mounting bracket kit
30) AV910321 - Avant Narrow Battery Plate
New updated or new parts
31) AV920356 Avant e-Aurora Pinion 11 Tooth Assembly
32) AV920357 Avant e-Aurora Pinion 12 Tooth Assembly
33) AV920358 Avant e-Aurora Carbon Bottom Plate
34) AV900237 Avant SE Main Shaft Special Edition for M4 Pin
35) AV910324 Avant 120 Engine Reinforcement Kit
36) AV000141 Avant CNC RigidCore™ Flybarless Dampener set
37) AV900240 Avant Special Edition Spindle
38) AV900050 Avant RigidCore™ Flybarless Head for 10mm shafts
New for 2012
New for 2013
AV900223 Avant Special Temper Main Shaft hub Sleeve for M4 Pin
AV000105 Avant 20T Metal Spur Gear
Raptor E700
RAPTOR G4 N // RAPTOR G4 E720
JR FORZA 700
Blade 130X fbl Brain  / 180 CFX
DX18
EASY-HELI.COM // OPTIFUEL // OPTIPOWER // Xnova motor
il me font penser a align, perso, je trouve que c'est du même level!
oula pas du tout comparable.... AVANT n'a toujours sortit qu'une machine et pas 50 versions... :handgestures-thumbupleft:
Je ne suis pas sûre que tu puisses adapté les pieces d'un 700DFC sur un tout premier Trex 700E...
Chez AVANT oui et ce n'est que du bon Upgrade !
Raptor E700
JR FORZA 700
DX18
en fait je disais plus ça d'en l'esprit que pour pour arriver a un hélico abouti il y a eu besoin de moult upgrades nécessaires
non chez avant ils y a des up-grade car tout au tour (moteur, fbl, etc) évolue. donc la marque réagit a ces nouvelles demandes.
tu change le moteur sur une voiture pour un plus puissant, il faut revoir le freinage, les suspensions, renforcer le chassie, etc. bien la s'est pareil ;)
momo
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
