mise a jour 2.6
Yes, en voila une bonne nouvelle.
Moi qui pensais que le développement avait été stoppé !
Firmware 2.6 adds the following functions to AC-3X:
- Additional 3D tailmode with extra crisp stop
- Automatic trimfunction on swashplate and tail
- Optimized swashplate algorithm very insensitive on center of gravity position!
- Servo reverse also on tail servo
Tiens ça resemble a la concurrence :lol:
Salut à tous,suite à la mise à jour sur mon Voodoo,tout fonctionne correctement sauf mon servo d'anticouple qui réagit étrangement(MKS BLS 980)de grands coups en buté!!!
Marcel as tu essayé le tiens aprés ta mise à jour?
Ai-je oublié quelque chose?
salut cedric,
pas de problème tu as activé l'auto-trim.c pourquoi tu as un "T" en haut a gauche.
Auto Trim: In this menu item the autotrim function of AC-3X can be activated. In the
autotrim mode AC-3X optimizes the trim parameters for all function automatically. The
activation of autotrim is indicated by a „T“ symbol in the left upper corner of the AC-3X
status screen. When activated, AC-3X optimizes trim parameters right away from the start of
the helicopter. After the flight the optimized parameters can be stored by pressing the lower
AC-3X button. The storage of the parameters is indicated by a „S“ symbol in the right upper
corner of the AC-3X status screen. When storing the trim parameters, it is important to set
pitch to 0° directly after landing as otherwise some additional trim offset might apear when
the helicopter is standing on the ground for longer times before pressing the lower button.
When the parameters are stored, the optimized parameters are available directly from the
beginning of the next flight. The trim values even persist when autotrim is deactivated. They
are reseted each time when autotrim is activated.
en gros si j'ai bien compris,tu fait un vol,tu pose,pas a zero,tu apuis sur le boutton du bas quelques secondes,un "S" ce met en haut a droite.ca comfirme que tu as fait ton auto-trim.du fait tu met tes accu comme un cochon et l'ac3x lui il s'en fout,il reprend le centre de gravité du vols que tu as fait avec un bon centrage.
laurent
  • 5 months later...
  • 2 months later...
