real flaight G2 compatible avec windows 7????
Bon bein apparemment la version G2 n'est compatible qu'avec Win XP . Pour preuve voici la réponse officiel des supports de chez real flight :
"Hello,
I regret the problems you are experiencing. However, the RealFlight G2 software is not supported under Windows Vista and 7. RealFlight G2 is only supported through Windows XP. The RealFlight G2 software has been reported to maybe work under Vista and 7 if the user disables the User Access Control (UAC) feature in Windows, but this process is part of the security scheme in Windows and is therefore not supported by RealFlight Support. If you wish to disable it, you may try so at your own risk.
We do recommend to upgrade to latest RealFlight versions that are compatible with the latest technology.
Help us serve you better! :-)"
Voila tout!!
