Sign in to follow this
djedje
Mise à jour des Kit 2010 //upgrade
Voici les mises à jour données par Avant pour ceux qui ont des kits inferieur à 2010,
ou veulent upgrader les versions Nitro. Les nouveaux kits produit ont ces mises à jour.
voici la liste des pièces:
The latest changes have been:
1) AV900240 - Smooth Spindle
2) AV000130 - Semi-rigid dampeners.
3) AV900239 - 4mm jesus pin hole in main shaft.
4) AV000801 - 4mm jesus pin.
5) AV900223 - 4mm pin hole main sleeve.
6) AV900211 - slightly enlarged constant drive gear for tighter mesh.
7) AV910300, 301 - Nitro frames have both back and top front gyro mount locations.
8) AV920350, 351 - Electric frames have new longer slots for large heavy batteries.
9) AV000108 - Electric frames have an extra 26mm spacer
10) AV000100 - Electric now has square mainshaft bearing blocks instead of the ones used in the nitro for no need for block orientation.
11) AV920350, 351 - Electric frames now have ESC on the left side
12) AV000123, 124 - Metal balls fit without a need to resize or squeeze the ball links
13) AV900202 - Torque tube is stiffer and harder
New in current batch of kits or about to be released:
1) New flybarless head needed a stronger solid mainshaft that will become the new default for all the kits.
2) AV000115 - Flybar carrier mounting sleeves allow for more thread inside the flybar carrier.
3) AV000801 - Tail pulley shaft pins are now easier to insert.
Additional to those all kits both nitro and electric now come with painted canopies.
Avant RC
Raptor E700
RAPTOR G4 N // RAPTOR G4 E720
JR FORZA 700
Blade 130X fbl Brain  / 180 CFX
DX18
EASY-HELI.COM // OPTIFUEL // OPTIPOWER // Xnova motor
Merci pour l'info Djedje.
Mon kit version 2009 est déjà en cours de montage comme sur la photo ci-dessous, et je l'adore.
Eduardo
T-REX 700E 3GX V2 / VELOCITY 50 / T-REX 600E PRO / Hitec Aurora 9
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
