Mikado lance sa radio Vbar control
  Intéressant, par contre c'est un nouveau protocol de communication géré par un satellite propriétaire qui se branche dans le vbar (exit donc les autres modèles sans Vbar ou les autres types de modèles: avions ...).
  Uli est bien moins à l'aise avec la vidéo ... "Eh Uli c'est celle du milieu qui tourne" :D
  Reste à voir si Ralph sera gourmand sur ce coup ^^
Séb
Plus d'info sur leur site :)
http://shop.mikado-heli.de/VBar-Control.htm?shop=k_mikado_e&SessionId=&a=catalog&t=7560&c=7560&p=7560
Software Highlights:
  • Set up, programming and adjusting of VBar-controlled model helicopters accomplished directly via VBar Control transmitter.
  • No computer, control panel or smartphone necessary.
  • Instant access to almost every flight parameter from the transmitter controls, even in flight.
  • Easy programming for new helicopters via the familiar VBar setup wizard.
  • New ESC setup wizard for programming all types of speed controllers.
  • Bank switching with three banks.
  • Real time logging and real time vibration analysis readable from the transmitter.
  • Several telemetry functions are available, such as voltages, current, rpm, speed, and power consumption of the batteries (may need aditional hardware).
  • Storage of event log files like VBar event log, VBar Control event log, GPS way points, voltage/current logging etc.
  • Multiple timer functions available with warnings and reminders via sound, voice, or vibration output.
  • Wireless buddy boxing with two VBar Control transmitters, fully configurable.
  • Easy bind process, allows bind and fly of any model equipped with VBar Control (e.g. a buddy‘s heli) with your own transmitter (Model Sharing).
  • Software updates via internet using a simple VBar Control Manager app and the web browser.
  • Option for adding new features via apps, simple installation via internet, supports both Windows and Mac OS X-PCs, no drivers needed.
  • Additional airplane software will be available in summer 2014.
Hardware Highlights:
  • 80 Channel 2.4 GHz FHSS bidirectional flight control, programming/setup and telemetry remote control system.
  • VBar Control Satellite Receiver connects directly to VBar flybarless controller via 2.4GHz VBar-Link protocol.
  • Unlimited model memory.
  • Virtually unlimited number of control channels.
  • High range, low latency, antenna diversity on both transmitter and receiver.
  • Intelligent antenna monitoring and management.
  • XXtra Bright Graphic Display featuring high contrast and ambient light sensor to automatically control the display brightness, making it equally well readable in bright sunlight and in the dark.
  • Easy Dialog System with rotary dial for convenient and safe inputs, with optical, tactile and acoustic feedback.
  • Precision gimbals with four ball bearings, fully adjustable.
  • Collective stick equipped with optional throw limiter.
  • Fully equipped with four 3-position-switches, two quick-break-switches and two rotation knobs, all fully programmable.
  • Delicate rubber lining for comfortable, slip-free and safe holding.
  • 3-point neck-strap attachment, for optimum balance.
  • Large 2 Watt loudspeaker for alarms and voice output.
  • Vibration alarm (adjustable).
  • Internal 8 MB flash memory.
  • Memory accessible as a USB memory stick, no drivers needed.
  • 4.000 mAh Lithium Polymer battery allows for long run times.
  • Charge through USB connector or built-in charger.
  • Power Supply for fast charging included.
cela doit etre vraiment trop cool pour regler le vstabi que j'utilise,une nouvelle bonne idée chez Mikado,c'est cool notre passion n'arrete pas d'évoluer... ;)
C'est marrant les gouts et les couleurs ;) perso je la trouve super moche,aprés faut peut etre s'y habituer ;)
Si Futaba  ou JR pouvaient intégrer le système de reglage du vstabi dans leurs modeles cela serait cool...
